Date/Time: Tue, 15 Sep 2026 16:06:00 +0000
suddenly 4 digits instead of 2, did not change display format in chart settings
View Count: 1219
| [2016-02-01 17:45:46] |
| BataviaTrader - Posts: 63 |
I have suddenly 4 digits in Emini and EOE future contract prices at the price scale. As far as I know I didn't change the price display format in chart setting, it still says 2 digits. However, 4 zero's are shown instaed of 2. Please advice, thank you.
| [2016-02-01 18:37:45] |
So the Price Display Format in Chart >> Chart Settings is .01? Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-01 18:47:22] |
that is correct, see http://upimg.me/images/e09d9a4f3602dc6b482bf814dc2ccb91.png
| [2016-02-01 18:59:03] |
The problem is the Heikin-Ashi study you are using has the wrong value format. Refer to this page for instructions: Changing the Price/Value Display Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
