Date/Time: Sat, 28 Dec 2024 23:52:15 +0000
QuoateBoard linked charts and line rectangle drawing
View Count: 758
[2016-02-01 16:21:06] |
User399855 - Posts: 10 |
http://www.sierrachart.com/image.php?l=1454343410864.png On each chart linked to the QuoateBoard I am drawing lines or rectangles. Sometimes the lines or rectangles from previous chart shows on the next chart. Is there a setting that will avoid lines being transferred to the next chart. All the charts are daily bar charts. |
[2016-02-01 16:44:32] |
Sierra Chart - Max - Posts: 5770 |
You need to disable Show Chart Drawings for Different Symbols under Chart >> Chart Settings >> Advanced Settings 2 (Bottom Right). For more details, please see: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ShowChartDrawingsForDifferentSymbol Sierra Chart Support |
