Date/Time: Sat, 28 Dec 2024 23:52:22 +0000
Volume Bar Delta
View Count: 3935
[2016-02-01 15:19:18]
User884307 - Posts: 173
Hi, what is the name of the Volume Bar Delta (not cumulative) , i can display it using subgraph difference but I read there ws now a dedicated indicator?
I keep looking through the studies but havent found it.
cheers
[2016-02-01 18:35:41]
Do you want to see the difference between Ask Volume and Bid Volume at each chart bar?
It is not clear exactly what you are looking for.
[2016-02-01 18:41:27]
Yes I want volume delta bars ...... i was reading this thread of which you addressed the issue apparently but i cannot find the indicator
https://www.sierrachart.com/supportboard/showthread.php?t=38587
cheers
[2016-02-01 19:03:59]
This is set through Chart >> Chart Settings. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar
You need to use the Bar Period Type >> Delta Volume Per Bar setting.
Date Time Of Last Edit: 2016-02-01 19:04:18
[2016-02-01 19:05:59]
No, im on about the volume not delta price bars
cheers
[2016-02-01 19:08:20]
AskV - BidV +/- zero line
[2016-02-01 19:16:10]
Therefore, use the Bid volume versus Ask Volume study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s127
