Date/Time: Fri, 18 Sep 2026 00:43:28 +0000
Limited to one connection per username for the requested data source.
View Count: 1423
[2016-02-01 14:42:27]
Cavalry3162 - Posts: 523
Hello Support,
today for the first time i get the following message on my second instance of SierraChart:
SC Data - All Services | Connected to server. | 2016-02-01 09:36:25
SC Data - All Services | Sending Encoding Request to server | 2016-02-01 09:36:25
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-02-01 09:36:25
SC Data - All Services | Sending logon request message. | 2016-02-01 09:36:25
SC Data - All Services | Server has requested a logoff. Reason: Limited to one connection per username for the requested data source. | 2016-02-01 09:36:25
Socket (46) | Shutdown and closed. | 2016-02-01 09:36:25
however, i have paid for 2 real time data connection.
please fix the issue asap, i need the data for my trading.
thank you,
Andreas
[2016-02-01 15:48:55]
SC any reaction?
i trade the US market and am waiting for more than an hour.. thats very annoying.
thanks,
Andreas
[2016-02-01 16:36:23]
Sierra Chart - Max - Posts: 5966
Let us know if you are still having this error.
How many copies of Sierra Chart do you have open?
For more details, please see:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
Sierra Chart Support
[2016-02-01 16:39:20]
yes, still getting this error:
SC Data - All Services | Connected to server. | 2016-02-01 11:38:04
SC Data - All Services | Sending Encoding Request to server | 2016-02-01 11:38:04
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-02-01 11:38:05
SC Data - All Services | Sending logon request message. | 2016-02-01 11:38:05
SC Data - All Services | Server has requested a logoff. Reason: Limited to one connection per username for the requested data source. | 2016-02-01 11:38:05
Socket (189) | Shutdown and closed. | 2016-02-01 11:38:05
i have two copies of sierra chart running and i pay for two connections - so this should be fine and was fine up until friday last week. the issue started today.
[2016-02-01 17:54:36]
Restart Sierra Chart and provide a copy of the Message Log by following these instructions:
[2016-02-01 17:57:34]
now its working again..(?)
anyway, thank you!
[2016-02-01 18:03:46]
Yes we can see that. We see that you have 2 connections active at this time for both stocks and futures. So this is actually a total of four.
For futures and indices there are 15 symbols and 5 symbols being tracked on the connections.
[2016-02-01 18:06:59]
so, you still need the log? am not sure what the ".. a total of 4" implies.
i have 2 instances running, sure, i track some stocks and futures but this is more like a usual usage, no?
thanks,
Andreas
[2016-02-01 18:22:24]
No, we do not need to see the Message Log if there is not a problem at the moment.
The 4 connections are normal in your case.
[2016-02-01 20:31:38]
We have temporarily resolved the problem now. The connections should be working.
There was a software update yesterday which caused this unexpected problem. We are permanently fixing it now.
[2016-02-02 04:04:47]
Refer to the information here:
Sierra Chart Exchange Data Feed Users with Multiple Data Feed Connections
