Date/Time: Thu, 10 Sep 2026 10:11:42 +0000
Hiding Studies
View Count: 1012
| [2016-02-01 13:37:53] |
| User727245 - Posts: 29 |
Is it possible to hide and show all studies at once from a chart instead of one by one?
| [2016-02-01 21:25:35] |
No, this is not supported. Unless they are removed from the chart.
| [2016-02-01 21:55:26] |
| Sawtooth - Posts: 4351 |
Try this:Save a Study Collection of all studies on the chart, then use the Clean Chart study collection to remove all studies, and the saved study collection to add them back. Saved study collections appear in the Analysis menu. Here's the documentation: http://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html |
