Date/Time: Sun, 29 Dec 2024 00:13:47 +0000
Sierra not updating from Friday Eurostoxx 50 March contract FESX
View Count: 716
[2016-02-01 07:39:29] |
User630405 - Posts: 1 |
Dear Sierra, Please fix above issue mentioned in the title. Thanks, Barry |
[2016-02-01 07:51:28] |
Your Sierra Chart account is expired and we have no idea what Data or Trading service you are using Sierra Chart with. Are you using the Easy Screen data feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
