Date/Time: Sat, 12 Sep 2026 18:17:50 +0000
multi connection at same time
View Count: 1952
| [2016-02-01 01:44:24] |
| User507693 - Posts: 9 |
Hi I have some question . Can i connect to several broker at same time and use their feeds for trading ? for example connect to LMAX and CURRENEX at same time and trade manually or automatic with their feeds? can i build a script that using brokers feeds and trade in one or two at same time ? for each broker that i want to trade i should open an account or you have a service for opening account with brokers? Regards. Date Time Of Last Edit: 2016-02-01 03:44:34
| [2016-02-01 09:27:26] |
Yes this is fully supported in Sierra Chart just by running individual instances of Sierra Chart. This is documented here: Using Multiple Data and Trading Services at the Same Time You will need to open an account with LMAX and Currenex. You will probably want to wait for LMAX because we are going to be changing the connectivity model to eliminate the connection cost. Here is information about automated trading: Automated Trading Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-01 15:13:23] |
do you have any plane for adding MT4 servers or any Api exist to connect your platform to mt4 servers? can you send me some education about you platform auto trade programming? thanks for your good support Date Time Of Last Edit: 2016-02-01 20:24:43
| [2016-02-01 15:57:00] |
why i can not see the market depth ? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=7004 Date Time Of Last Edit: 2016-02-01 20:24:30
| [2016-02-01 20:06:32] |
Sierra Chart cannot support MT4. This is not technically possible. Instead they should support the DTC Protocol: http://dtcprotocol.org/ For automated trading, this is the main documentation page for that: Automated Trading Management It links to two methods of automated trading. One is spreadsheets and the other is using ACSIL. Instead of SPH16 you need to use ESH16. There will not be market depth data though unless you are subscribed to a supported real-time futures data feed. For the Bitcoin symbol, there is market depth data available. Here is the documentation about that: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php#MarketDepthData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-01 20:07:28
| [2016-02-01 21:57:56] |
I can not find any market depth in DOM windows service packages 5 include market depth ? or for market depth i should register with exchangers data feeds ? Date Time Of Last Edit: 2016-02-01 22:26:48
| [2016-02-01 22:01:55] |
if I have rithmic or CQG account and connect them to sierra .I can see the full details such as market depth that i can see in their platforms?or I should pay any fees ?
| [2016-02-01 22:35:17] |
For futures market depth, you need to use a real-time futures data feed. You can use your Rithmic or CQG account. There are no additional fees. The services are listed here: https://www.sierrachart.com/index.php?page=doc/Data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-01 23:39:07] |
you said i should subscribed to real-time futures data feeds for futures depth , it means your data feeds with your packages dos not have real-time futures data?
| [2016-02-01 23:51:12] |
For information about futures data refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php#AltToFuturesData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-02 19:43:55] |
please answer me clearly with your data feed without any external data feeds and future trade account ,can i see the depth in DOM area ?
| [2016-02-02 19:51:04] |
Yes you can but you have to pay for the data feed and you are going to pay a lot of money if you want CME data. Here is the data feed you can use: Sierra Chart Exchange Data Feed Also, the documentation is very clear on this subject. The documentation also explains how much you have to pay without a supported trading account. We spend a lot of time answering these kinds of questions and the issues always surround exchange rules which we have no control over. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
