Date/Time: Tue, 15 Sep 2026 17:53:11 +0000
How to use a use a study function within a study without outputting/plotting its value
View Count: 1263
[2016-01-31 08:26:40]
User972044 - Posts: 154
Hi there,
I need to use a study function e.g. ATR to calculate a value that will be outputted onto the chart but I really don't need the actual ATR value to be outputted. For example, this is what I would like to do:
sc.Subgraph[0].Data[sc.index] = ATR * 10;
It says that if you don't want the ATR value to be plotted, you have to use Subgraph.Array[0] so do I use Subgraph.Array[0] as the output parameter? Is that correct? Also, my second question: how do I actually call the function?
Do I use sc.Subgraph[0].Data[sc.index] = sc.ATR(...) * 10; ?
Thank you for your help in advance. This is very new to me and I am very confused.
[2016-02-02 10:13:16]
Here is the relevant updated and added documentation:
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#WorkingWithIntermediateStudyCalculationFunctions
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#ArrayNotes
Even when using sc.Subgraph if you do not want it to be visible simply set the DrawStyle of it to Ignore. The documentation explains this with a code sample.
Here is the updated documentation for sc.ATR:
ACSIL Interface Members - Functions: sc.ATR()
You can use either a sc.Subgraph or sc.Subgraph[].Arrays[]. There are two implementations of the function.
