Date/Time: Sat, 28 Dec 2024 23:56:25 +0000
[User Discussion] - Spreadsheet Entries with Zig Zag Study Problem
View Count: 2300
[2016-01-30 05:59:50] |
sigmadict - Posts: 95 |
Hello, I am using the Spreasheet Study for Trading, alongside with the Zig Zag Study and my problem is the following : On the Spreadsheet Study for Trading, I have No Entry Signal in Columns K, M, (i.e the value is 0, not 1, printed in the Cell), and the Spreadsheet generates Buy/Sell Entry Signals on erroneous locations. I understand that the Zig Zag lines are updating constantly and that it could generate a New Signal on a New Bar, but with my coding, the parameters of the Studies (on Bar Close, see below), and the visual confirmation that there is No Buy/Sell Entry Signal (0 values in Cells of Columns K, M), from my understanding, the Automated Trading should not occur. Maybe I am forgetting a little detail with the Parameters of the Studies, so I am asking your Help to Solve this Problem. The Parameters from the Studies: //Zig Zag study ; -Calculation Mode 2 -Number of Bars Required for Reversal : 10 -Calculate New Values On Bar Close : Yes //Spreadsheet Study for Trading; -Reset Conditions On New Bars : Yes -Do Not Output Subgraphs Set To Ignore : Yes -Signal Only Once Per Bar : Yes -Signal Only On Bar Close (Columns L, N-Z) : Yes -Signal Only On Bar Close (Columns K, M) : Yes -Strict Signal Only On Bar Close evaluation : Yes I will also attach a Screenshot to this Message to illustrate my Problem. If you look on the Chart, at around 9:45, 9:50 am, the Zig Zag makes a Higher Low at 1840.75 ESH6 points. After the Low is made, we are going back up with the Candles, and the Replay with Accurate Trading Automation takes exactly 6 Short Trades (see Pink Signals), during the ascension. During that same exact ascension, the Spreadsheet Study for Trading did Not generates any Entry Signals, and I get 6 Erroneous Trades. Could you please Help me to Find the way to Solve this Issue ? Thank you Regards http://www.sierrachart.com/image.php?l=1454133566288.png |
[2016-01-30 07:05:08] |
Hello again, So I was Investigating, and I realised that I forgot to mention that I use $J$8<1, and $J$8>-1, for Buy/Sell Entries, because I don't want to flood the Trade Log with messages. Could it be the reason why I don't have Entry Signals in Columns K, M ? If so, Why do I have 37 Entry Signals in Columns K, M ? (over 250 Total Trades, over 3000 bars) If that is the problem... Regards |
[2016-01-31 00:47:09] |
I tought about something else. Maybe because the Zig Zag is always re-updating, until the new High or Low is made, it changes my Prior Conditions that are based on the Zig Zag. So maybe that's why I can not rely on Entry Signals from Columns K, M . Let me know what you think please if you can confirm what I think is the problem. Thanks Regards |
[2016-01-31 03:06:09] |
Your conclusion in post #3 sounds reasonable. Otherwise, this support request is outside the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
