Date/Time: Sun, 29 Dec 2024 15:35:47 +0000
SC Intraday feed
View Count: 944
[2016-01-29 21:59:45] |
dominikos - Posts: 106 |
When I choose SC Intraday delayed price feed, should it refresh? I find that the only way to have it refresh data is to disconnect and connect. Perhaps I'm missing a setting?
[2016-01-29 22:12:00] |
Yes, you do have to reconnect to bring the charts up-to-date.
[2016-01-29 22:40:11] |
But we do plan to implement periodic updating at user-specified interval. But probably not less than every 15 minutes.
[2016-01-30 00:59:28] |
Thank you, that would be useful.
