Date/Time: Fri, 18 Sep 2026 04:34:34 +0000
shifting lines on non-time based charts
View Count: 1174
[2016-01-29 21:09:14]
User184859 - Posts: 17
First, congratulations on creating a fabulous charting package. It makes NinjaTrader feel like a toy. I don't need a reply to the referenced issue as I understand the limitation and how to work around it. The thing is that I never noticed this problem when using NinjaTrader. For example, if I change the number of days of data loaded, the lines on your chart will shift, but not on NinjaTrader. Just an observation and reported strictly for your benefit.
[2016-01-30 04:14:51]
This is explained in detail here:
https://www.sierrachart.com/index.php?page=doc/helpdetails34.html
There are no good solutions for a problem that has no definite solution and it is easy enough for the user to understand what is happening and avoid the problem to begin with.
Thank you for the comment.
Date Time Of Last Edit: 2016-01-30 04:15:51
