Date/Time: Sun, 29 Dec 2024 16:13:48 +0000
How to lock drawing o candle?
View Count: 780
[2016-01-29 14:33:26] |
User76837 - Posts: 7 |
Hello I was wandering if there is possibility to lock drawing to candle. For example If I draw ray tool from specified candle and there will be contract rollover the line will stick to price not to candle, and I want to lock this line to hihg or low of that candle. Can You help me. Kind regards Luxios |
[2016-01-29 18:03:09] |
This is already the case. There is nothing special to do. So long as you are not using the back adjusted Continuous Contract options.
