Date/Time: Sun, 29 Dec 2024 15:05:54 +0000
Spreadsheet / Quoteboard
View Count: 996
[2016-01-29 11:03:03]
tobi - Posts: 351
Thinking about putting together a SC Spreadsheet to use as QuoteBoard, instead of using the SC QuoteBoard. Reason is, that the SC Quoteboard only has limited Fields available and/or doesn't allow individual calculations for the Fields.
But, are the following things from SC Quoteboard also available/possible in SC Spreadsheets?
- to get the Last Tick (+ or -)
- to highlight cells if certain conditions are met (e.g. if the previous low of the day is taken out or the last price is within 2 ticks of the high of the day)
[2016-01-29 11:24:50]
1. The Last Tick field is supported with Quote Spreadsheets.
2. Automatic highlighting is not supported with Quote Spreadsheets.
[2016-01-29 11:39:51]
tobi - Posts: 351
My question was not related to "Quote Spreadsheets". It was related to "Spreadsheets" (the idea is to individually build it together to my needs).
How do I get the Last Tick into the Quote Spreadsheet?
[2016-01-29 17:42:47]
The spreadsheet needs to be set to a Quote Spreadsheet. Refer to this section here:
https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuotesOnSpreadsheets
The Spreadsheet can also be used by the Spreadsheet Study.
