Date/Time: Thu, 17 Sep 2026 21:30:41 +0000
Modify or remove chart window title bar text?
View Count: 4832
| [2016-01-29 00:45:45] |
| trader1 - Posts: 128 |
Hi, Is it possible to modify or remove the text in the title bar of a chart window? Thanks. |
| [2016-01-29 17:44:28] |
You can modify what is called the Chart Header in the Region Data Line. Refer to: Working With Charts: Region Data Line / Chart Header It is not possible to modify the top title bar of a chart window. Although it is possible to add additional text to it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
