Date/Time: Sun, 29 Dec 2024 00:24:57 +0000
SC Version 1362 : I have problems with update charts
View Count: 1037
[2016-01-28 19:04:37]
salsem - Posts: 43
chart 6E NOT UPDATE
imagesc version 1362 6E.jpg / V - Attached On 2016-01-28 19:03:48 UTC - Size: 43.04 KB - 297 views
[2016-01-28 19:11:19]
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart
What Data or Trading service are you using or do you wish to use? See this page for the list:
http://www.sierrachart.com/index.php?page=data.php&CAID=def
Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to?
[2016-01-28 20:32:03]
salsem - Posts: 43
AMP / TTNet
I have problems with update date
delete and dowland data is crash and jumping (is not correct)
not running 01/28
problems various historical data
thank in advance
[2016-01-28 20:39:11]
For reasons unknown there has been a persistent problem with the 6E data from the TT FIX adapter that Trading Technologies has not yet addressed.
Rather unbelievable.
Disable the error filtering and re-download the data:
https://www.sierrachart.com/index.php?page=doc/doc_ErrorFilter.html#DisablingErrorFiltering
[2016-01-28 20:57:25]
salsem - Posts: 43
with this move the problem is solved ... but the data is reliable and accurate....for trading ?
[2016-01-28 23:08:08]
As long as you do not use trading commands which depend upon the Bid or Ask because those are 10 times the actual price values.
[2016-01-29 12:23:57]
salsem - Posts: 43
idem problems with eurex :(
[2016-01-29 18:36:07]
What exactly is the problem with the EUREX?
[2016-02-02 14:17:47]
salsem - Posts: 43
jumping ,
not correct update all Eurex futures
imageFDXM 201603.jpg / V - Attached On 2016-02-02 14:17:18 UTC - Size: 61.17 KB - 289 views
[2016-02-02 14:22:26]
We see there is missing data from the chart. Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart
Date Time Of Last Edit: 2016-02-02 14:22:52
[2016-02-02 15:18:05]
salsem - Posts: 43
appare this message on chart FDXM "Dowloand Failed"
[2016-02-02 15:28:54]
salsem - Posts: 43
missing data from the chart FGBL
imageFGBL.jpg / V - Attached On 2016-02-02 15:28:39 UTC - Size: 65.42 KB - 295 views
[2016-02-02 19:04:23]
Follow the instructions here to Update the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
After that is done re-download the data for the FDXM chart with Edit >> Delete All Data and Download.
Regarding missing data for FGBL, it is not obvious from the chart image provided that there is missing data. However, refer to the information on this page about this:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData
