Date/Time: Mon, 28 Oct 2024 08:57:48 +0000
CROSS HAIR
View Count: 668
[2016-01-26 01:58:59] |
User57072 - Posts: 49 |
I CAN NOT GET THE CROSS HAIR TO COME ON, POINTER IS ON ALWAYS. HOW CAN I GET THE CROSS HAIR TO COME ON?
[2016-01-26 03:15:37] |
You need to use the Chart Values tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
