Date/Time: Mon, 28 Oct 2024 08:57:48 +0000
Evening session
View Count: 737
[2016-01-26 01:53:00] |
Kinobe - Posts: 86 |
Hi Is it possible to change the background color of the evening session period (post-market and pre-market)? or at least get a horizontal line at the beginning and the end of the evening session? that will facilate to discern the period of evening session vs the regular period (9h30 to 16h30). thank you |
[2016-01-26 03:16:14] |
Yes you can do this with the Time Range Highlight study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s278 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
