Date/Time: Mon, 28 Oct 2024 08:57:48 +0000
Add Column to Spreadsheet (OLD Version)
View Count: 607
[2016-01-26 01:40:02] |
User26445 - Posts: 6 |
When I insert a column between Column H & I then save the chart book the column disappears from the spread sheet when reopened. Can this be saved and remain in the spreadsheet? Thanks Dave |
[2016-01-26 01:56:10] |
If you are using the Spreadsheet Study with that Spreadsheet, we do not see how this is going to work under any condition.
