Date/Time: Tue, 08 Sep 2026 22:54:06 +0000
Automated trading not send to Trading service
View Count: 1074
| [2016-01-25 20:05:48] |
| jochenfrenzel - Posts: 8 |
Hello, I do automated trading with the (old) spreadsheet system. On certain circumstances I want to to execute the trade WITHOUT sending it to the Trading service - that means only simulated. It's because I need the result of this simulated trade for further decisions. I know I can Stop the execution with "Auto-Trading Enabled" but then I don't have this information. Are there such possibilities in automated trading? Thank you! |
| [2016-01-25 23:14:04] |
You need to use Trade Simulation Mode: Trade Simulation And refer to: Automated Trading Management: SendOrdersToTradeService Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-26 13:14:05] |
But "Send Orders To Trade Service" (field J68 in spreadsheet) is read-only. Is it possible to change this value from the spreadsheet?
| [2016-01-26 18:12:49] |
Not from the spreadsheet. This can only be done from the study Input settings: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-26 19:07:21] |
But thats not automated. I simply want to do this in my spreadsheet: - I start a series of trades without sending the information to the trading service - As soon as the last tradingresult is positive I want to do the next trade sending the information to the trading service - and so on is that possible? Thank you! |
| [2016-01-26 19:36:04] |
OK we will see how we can make this an option on the spreadsheet.
| [2016-01-26 19:39:18] |
Thank you! Thats great!
