Date/Time: Mon, 28 Oct 2024 08:57:49 +0000
Horizontal line density adjustment?
View Count: 713
[2016-01-25 17:08:53] |
User20683 - Posts: 12 |
How can I reduce the density of those horizontal lines? http://www.sierrachart.com/image.php?l=1453741023281.png I have the scale set to 5 on the right and I only want a horizontal line at those increments (1885, 1890, 1895, 1900, 1905, etc) Thanks |
[2016-01-25 21:31:57] |
We see the problem with this and we will be solving it today.
