Date/Time: Thu, 24 Sep 2026 22:09:28 +0000
Number Bars
View Count: 1146
[2016-01-25 16:57:30]
User96015 - Posts: 55
Dear sir, I need to get an information. I applied Number Bars study and I need to calcuate it based on UP/DOWN Tick.
Can I do it?
Thx.
[2016-01-25 17:25:52]
We do not understand this.
Numbers Bars do have the ability to display Bid Volume and Ask Volume at each price level. Here are instructions:
Numbers Bars
[2016-01-26 08:04:06]
Yes sir. I know it.
But you can also display delta and delta can be calculated baesd Ask Volume - Bid Volume or Up Tick - Down Tick.
Like there are two studies Cumulative Volume Delta- Volume and Tick, I' d like to know if there are the same possibiliy
for Number Bars.
Thanks.
[2016-01-26 08:27:56]
Numbers Bars can display the difference between Ask Volume and Bid Volume.
However, not Upticks and Downticks.
[2016-01-26 09:03:12]
Ok perfect.
But I try to apply Number Bars on Forex and it display bid and ask trades, even if Forex doesn' t have book.
Why?
[2016-01-26 09:15:54]
When using Numbers Bars for Forex symbols, effectively the bid volume and ask volume are up ticks and down ticks.
This is documented here:
Chart Data and Chart Data Files: Volume Data
[2016-01-26 09:56:29]
ok perfect.
I' ve got another question.
I'm plotting number bars on the chart and VBP on the right. The problem is that bars of Number Bars, after a pair of bars, going above the VBP.
Is there the possibility to keep always the same distance between bars and VBP, such as bars never going above VBP?
Thx.
[2016-01-26 10:22:50]
[2016-01-26 10:32:58]
No, maybe I wxpalin the problem bad.
The problem is that I have bars over the VBP as u can see in the file attached.
I' d like to know if there is the possibility to keep a fixed space between bars and VBP, in such a way that
Number Bars never been plotted over the VBP.
imageBDH16 [CB] 1 Trades #20 2016-01-26 11_29_12.261.png / V - Attached On 2016-01-26 10:32:52 UTC - Size: 59.7 KB - 538 views
[2016-01-26 19:05:31]
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#RightAligning
