Date/Time: Sat, 03 Oct 2026 11:43:38 +0000
Evening Profile different colors
View Count: 1277
| [2016-01-25 13:49:29] |
| User341584 - Posts: 44 |
I copied my SC files to my laptop. Now my evening volume profile study has a different colors for evening session. Not sure how it happend, but I like it. How is this accomplished? Thanks Matt |
| [2016-01-25 17:54:35] |
There is a new Subgraph setting on the Subgraphs tab of the Study Settings window to control the colors for the evening session Volume Profiles. Refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-25 18:37:38] |
Awesome Thanks I also had to update to current version. Thanks Matt |
