Date/Time: Mon, 28 Oct 2024 08:57:49 +0000
Data availability with Infinity trial
View Count: 655
[2016-01-25 12:39:29] |
skelcap - Posts: 139 |
Hi I have a trial account with Infinity and want to see intraday data for $INX the cash S&P 500 Index. Currently I can only see daily data. Is it possible?
[2016-01-25 17:55:56] |
This requires both a direct account and that you are using the Sierra Chart Exchange Data Feed. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
