Date/Time: Sun, 27 Sep 2026 14:35:03 +0000
No real-time/historical data for CQG prompt month ICS
View Count: 1133
[2016-01-25 11:27:13]
User11942 - Posts: 298
Hello SC team, F.US.CLEBZH16 isn't showing up. Apparently CQG have recently made some changes on their side. Normally, I can see it on CQG front-end like CLEBZH6 but since this am it can be found as CLEBZH16 but both symbols do not work on Sierra. So, not tradable. Please advice. Thanks.
[2016-01-26 00:23:33]
We see no problem with this symbol:
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEBZH16. Request ID: 56194. Contract ID: 155. | 2016-01-25 19:22:36
CQG FIX Trading | Requesting market data for F.US.CLEBZH16 | 2016-01-25 19:22:36
Works just fine. We received historical chart data as well from CQG.
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2016-01-26 00:23:53
[2016-01-26 00:33:14]
Well, they have already fixed it earlier today. In the morning it was unavailable. I suggest the ticket is closed. Thanks.
CQG FIX Trading | Logon successful. Session Token = luuD0OtnsytK63QScxqnfXOYtgFD2NP+mNCn2CM1vjE | 2016-01-25 07:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.CLEBZH16. ID: 13104 | 2016-01-25 07:40:54
Symbol Error - F.US.CLEBZH16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2016-01-25 07:40:54
If you need the entire log, I can send it to you.
Date Time Of Last Edit: 2016-01-26 00:35:51
[2016-01-26 00:39:40]
Therefore, there is nothing further for us to do with this since it was a CQG issue.
We do not know what the problem was.
