Date/Time: Sun, 13 Sep 2026 06:30:37 +0000
Data for WIN # does not load completely.
View Count: 1024
| [2016-01-25 09:08:39] |
| User259538 - Posts: 1 |
Hi, Data for WIN # does not load completely. Attached Message Log. Thanks, |
| [2016-01-25 09:52:47] |
Disable Error Filtering as explained here: https://www.sierrachart.com/index.php?page=doc/doc_ErrorFilter.html#DisablingErrorFiltering After this re-download the data in the chart with Edit >> Delete All Data and Download. There are apparently many data errors in the data. The error filtering is filtering those out but may also be filtering out some valid data as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-25 09:53:10
