Date/Time: Thu, 31 Oct 2024 12:18:53 +0000
How do I upload my Sierra charts that I use now to another computer?
View Count: 1061
[2016-01-22 19:16:02] |
User992108 - Posts: 31 |
How do I upload my Sierra charts that I use now to another computer and what info do I need? Where do I get the info to use to make this happen? ..............Thank you..........Richard Date Time Of Last Edit: 2016-01-22 19:28:45
[2016-01-24 06:24:40] |
Refer to: https://www.sierrachart.com/index.php?l=helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-26 02:05:14] |
Yes I've done that, but when I Log into Sierra charts on both computers it says "waiting to reconnect" and stays yellow. How do I stay connected (Green) on both computers? |
[2016-01-26 03:13:40] |
We see you are using CQG and CQG does not allow simultaneous connections. Sierra Chart will be offering a solution to this though in approximately one month. We were hoping to have it done by the end of January but it is not completely ready. But basically this is the DTC Server feature: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-26 03:14:12
[2016-01-26 15:56:56] |
Ok, so can I get this connected today? I really need this to up and running today. I dont understand the page and where to Establish a TCP/IP network connection to 127.0.0.1 using the specified port number? Can I get some help?? via a call. It would be massive help. Please and thank you. Richard Date Time Of Last Edit: 2016-01-27 05:04:45
[2016-01-27 05:03:57] |
This feature is new and is quite advanced usage. We think it is best that you wait until it is finalized and properly documented. We are not ready at this point provide further help with it. Also, when the feature is done, there are some technical complexities to it when using it across the Internet like firewalls. It is going to be primarily the responsibility of the user to handle networking related issues to get the connection working. This is something that we will not get involved with other than saying that you need to allow the connection through firewalls and routers. Do you need to be connected to CQG from both systems at the same time? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-27 05:06:13
[2016-01-29 03:39:10] |
Yes, CQG is my only connection that I trade with. And I need to run 2 separate systems . How can we do this?
[2016-01-29 18:35:14] |
Please allow us about another two weeks. This is the best we can do.
[2016-01-29 19:34:15] |
yes of course. I'll just not do certain trades. Please let me know when its avail. Thank you
