Date/Time: Thu, 26 Sep 2024 23:34:10 +0000
Teletrader Data Service: Symbols unknown
View Count: 937
[2016-01-22 07:12:22] |
tobi - Posts: 351 |
The following symbols (index, sectors) from Teletrader Data Service show "Symbol unknown" and "Download Failed": NDX.X.IND.Indizes NAS (NASDAQ 100 INDEX) NBI.X.IND.Indizes NAS (NASDAQ BIOTECHNOLOGY (DRM)) IXF.X.IND.Indizes NAS (NASDAQ FINANCIAL 100) Note the different syntax regarding the "X" in other symbols that do work, e.g. COMPX.IND.Indizes NAS (NASDAQ COMPOSITE INDEX) BANKX.IND.Indizes NAS (NASDAQ BANK) |
[2016-01-22 08:36:43] |
We are solving this now.
[2016-01-22 09:41:09] |
tobi - Posts: 351 |
Still the same. Anything to do on my side (Update from Server or Full Reset in Global Symbol Settings)? |
[2016-01-22 10:00:16] |
You will need to wait for the next release which we will have at the end of the day.
[2016-01-23 05:56:46] |
tobi - Posts: 351 |
Still don't get the data. Let me know when this will be fixed / the new release will be available.
[2016-01-23 08:18:19] |
We were not able to do a release yesterday because there are some unrelated changes we need to finalize first. We do fully expect to have a new release out before the Monday open. The version will be 1358. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-25 15:03:54] |
tobi - Posts: 351 |
No realtime data for NDX.X.IND.Indizes NAS (NASDAQ 100 INDEX). The others from post #1 are working fine.
[2016-01-25 15:37:30] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-25 16:04:40] |
tobi - Posts: 351 |
Working now (after restart / reconnect of SC). Have you changed anything?
[2016-01-25 16:06:20] |
No we have not. Your Sierra Chart also would not have been affected by any changes without updating to a new version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
