Date/Time: Sat, 28 Dec 2024 22:38:11 +0000
defaultSpreadsheetStudy.scss
View Count: 833
[2016-01-22 00:35:46]
User553714 - Posts: 184
Hi there,
I have started wading through the online documentation for setting up and using spreadsheet studies and couldn't find an answer to the following question;
When I add any of the following 3-off standard studies;
- Spreadsheet system for trading
- spreadsheet study
- spreadsheet system/alert
The same spreadsheet is opened for all of the above 3-studies named - DefaultSpreadsheetStudy.scss? Is this correct and are the sheets that appear all the same or different in some way. Is there any way to identify which is which?
Thanks for your help.
Regards
[2016-01-22 04:41:33]
In the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php#Instructions
You need to follow the step to set the Spreadsheet Name setting from the default in the Study Settings window for the Spreadsheet study.
