Date/Time: Thu, 28 Nov 2024 00:26:13 +0000
Show Orders & Positions & Show Order Fills
View Count: 1579
[2016-01-21 21:01:25]
User266903 - Posts: 26
When chart trading is enabled, I can uncheck "Show Order Fills" and the trade entry & exit markers disappear. This is good. However, if I uncheck "Show Orders & Positions". it stays checked, and all active order & position markers are shown on the chart. Why is this? Thanks!
[2016-01-21 21:31:41]
What is the purpose of the question?
The answer should be apparent. What is the purpose of putting the chart in Chart Trade Mode and not having the orders and position on the chart. What you are looking for clearly is unsupported and does not make sense.
There is no way to submit an order from a chart and not see that order.
Date Time Of Last Edit: 2016-01-21 21:33:11
[2016-01-21 21:33:48]
So I can still right click and "Sell Limit", "Buy Stop" etc.?
But okay. I will just disable trading on that chart. It just gets too congested sometimes with all the lines, and I use multiple charts anyways with very different bar resolutions.
Date Time Of Last Edit: 2016-01-21 21:35:40
[2016-01-21 21:40:38]
You really just have to disable Trade >> Chart Trade Mode. There is no other way around this.
[2023-06-15 11:09:56]
User727459 - Posts: 4
Hi, I only want to see the arrows where I took the position, not the quantity of contracts or level it was taken, is there a way to do this ?
[2023-06-15 14:11:07]
John - SC Support - Posts: 36350
Refer to the settings in this section:
Global Trade Settings Windows: Order Fills (Global Settings >> Chart Trade Settings >> Order Fills)
