Date/Time: Sat, 28 Dec 2024 22:38:47 +0000
indi ?
View Count: 892
[2016-01-21 16:51:47] |
User20450 - Posts: 330 |
are the any indicators that will allow me to show the difference in movement between to things , like diff in movement of crude and Es ? not an overlay but a indicator that will show when there close and when there moving apart ? thanks |
[2016-01-21 18:08:19] |
Use the Difference (Bar) study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-21 18:09:06
[2016-01-21 23:15:08] |
yea i tried that but all its doing is subtracing the es from cl giving me math , i want a histogram % on movement
[2016-01-22 04:42:37] |
Therefore, refer to this page and see how you can put together a custom calculation: http://www.sierrachart.com/index.php?page=doc/doc_ArithmeticStudies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
