Date/Time: Sat, 28 Dec 2024 23:09:42 +0000
$Tick Data
View Count: 789
[2016-01-20 21:56:39] |
User818051 - Posts: 4 |
My Question is can the data on the Tick chart be different from Broker to Broker and are there Adjustments on the $tick to cause the data to be different. Today on open some platforms had a -1400 Tick but the $tick, I use with Sierra, only opened with a -400 tick. Can anyone assist me.
[2016-01-20 23:22:00] |
Yes there can be differences due to different calculation algorithms. Refer to: Article about Sierra Chart Market Statistics and their Accuracy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
