Date/Time: Sat, 28 Dec 2024 23:34:07 +0000
indicator?
View Count: 976
[2016-01-20 10:47:17] |
alex@n - Posts: 20 |
Hello, this picture found on the forum futures.io (BMT), your thoughts are what this indicator? maybe it's - all buyers, all sellers? maybe it's the delta? your thoughts on this? |
indicator.bmp - Attached On 2016-01-20 10:46:36 UTC - Size: 2.25 MB - 390 views |
[2016-01-21 15:45:05] |
Really no thoughts on this indicator?
[2016-01-21 18:02:30] |
It is best that you describe what is that you are looking for.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-21 18:02:46
[2016-01-21 18:27:47] |
Thanks for the answer . How to create such a study? on this page Additional Files (Study Collections, Spreadsheets, Chartbooks) , here is a study - CumulativeAskBidVolumeDifference.StdyCollct [Study Collection file] This may be similar to picture above? |
[2016-01-21 18:32:26] |
For this you can use the Cumulative Delta Bars studies: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s292 Here are the instructions to use a study: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-21 18:38:33] |
OK ! Thank you . yes, it's very similar to that I am looking for. |
