Date/Time: Sat, 28 Dec 2024 23:34:35 +0000
NumBars in DOM
View Count: 1213
[2016-01-20 05:55:58] |
nicktrader - Posts: 722 |
Is it possible to insert the NumBars into the DOM. I tried with Study/ Price overlay but it do not work. Is it possible in principle and if "Yes" how? Many thanks |
[2016-01-20 07:49:58] |
Yes, but really the proper way to do this is to use a standard chart with the Numbers Bars study and enable the Chart DOM on that: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-20 12:32:19] |
Many thanks but I do not like to work with a Chart DOM. Please find attached what I am looking for. I copied (as an excample) a NumBar (M5) into the DOM. I'd like to see only the last Bar of that M5 Chart. Is that possible? |
DOM + NumBars.png / V - Attached On 2016-01-20 12:27:37 UTC - Size: 24.99 KB - 305 views |
[2016-01-20 16:16:14] |
User60518 - Posts: 106 |
Hi, You can add the volume by price study to the DOM, and there is a setting to 'Display Volume in Bars', selecting 'Bid Volme x Ask Volume' might give you what you are after |
Capture.JPG / V - Attached On 2016-01-20 16:16:03 UTC - Size: 98.7 KB - 449 views |
[2016-01-20 17:28:05] |
Many thanks for your help but your suggestion is not exactly what I am looking for. The advantage of the NumBars is that you see the development in the current M5 candle (for example). The Volume by Price study gives back the development at this price over the day. |
[2016-01-20 18:55:06] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#AddingStudiesTradeDOM You will also need to change your service package to service package 5 to use the Numbers Bars study. To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package". The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
