Date/Time: Sat, 28 Dec 2024 19:51:00 +0000
[User Discussion] - use fill top/fill bottom for two independent studies to create color band
View Count: 873
[2016-01-19 18:59:42]
User380760 - Posts: 88
I want to create a color band between two studies, such as two types of moving averages not included in the study "Moving Averages". I tried to create a study subgraph reference, but when projected to the main graph, it's not proportional to the real value. How can I achieve it?
[2016-01-19 19:28:02]
This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#FillingArea
For scaling, just make sure that the Scale Range for those studies is set to "Automatic"
[2016-01-19 20:02:47]
I have no problem doing this color band when the two study graphs are in the same study provided by sierra chart. But when I am trying to do that for two different studies, the resulted band is out of proportion. I did set the scale range to automatic.
[2016-01-19 21:02:22]
Sawtooth - Posts: 4143
To fill between the subgraphs of two different studies, use the Study Subgraphs Reference study.
