Date/Time: Sat, 20 Jun 2026 14:32:10 +0000
CrossFromAbove or CrossFromBelow
View Count: 3372
| [2016-01-19 15:53:10] |
| FXDojiStar - Posts: 8 |
I am using the Ichimoku Tenken-Sen crosses the Kijus-Sen as the base of the system WITH the Price staying below the cross as the trigger. I wrote the formula and placed in the System Alert Condition section. UNFORTUNATELY I cant get it to work. Here is my formula: ID6 = Tenken-Sen ID4 = Kijun-Sen =( CROSSFROMABOVE(ID6.SG1, ID4.SG1) AND (ID6.SG1 > C)) OR ( CROSSFROMBELOW(ID6.SG1, ID4.SG1) AND ( C > ID6.SG1) ) I have ticked - Enabled, Evaluate on bar close. Thanks |
| [2016-01-19 19:16:24] |
That formula does not make sense. You are improperly using the AND and OR functions. Refer to the documentation here for these functions: Spreadsheet Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-19 23:59:11
| [2016-01-19 23:18:14] |
| Sawtooth - Posts: 4333 |
Try this syntax: =OR(AND(CROSSFROMABOVE(ID6.SG1,ID4.SG1),ID6.SG1>C),AND(CROSSFROMBELOW(ID6.SG1,ID4.SG1),C>ID6.SG1)) |
