Date/Time: Sat, 28 Dec 2024 18:59:59 +0000
Some problems with Time Settings
View Count: 686
[2016-01-19 13:18:42]
JRA - Posts: 97
Today I noticed after the last update, a problem.
I am running a remote instance for IQFeed, and one Trading instance with IB. I load ES. I use Volume charts with the timings of CME and Time zone Chicago. But now the trading instance gives different bars, and playing with it found that if i set on the remote instance my current time zone settings(Athens) then I have the same bars as in the trading instance which is set on Chicago Time Zone. Pls look at it. The difference is small but its obvious from 04:13 today chicago time.
Remote Instance (IQFEED):http://www.sierrachart.com/image.php?l=1453209645981.png
Tradind Instance :http://www.sierrachart.com/image.php?l=1453209698859.png
Both On Same Time Zone Chicago
Date Time Of Last Edit: 2016-01-19 13:22:00
[2016-01-19 13:26:56]
JRA - Posts: 97
Please Disregard the post, My Mistake, I had loaded on the remote chart the continuous contract from IQFeed. Deeply sorry!!!
