Date/Time: Thu, 12 Nov 2026 12:58:05 +0000
Buy/Sell Marked on Chart
View Count: 1039
| [2016-01-19 11:11:52] |
| User55519 - Posts: 37 |
Hello, I have searched for an answer to this, but have not been able to locate one. Is there a setting that will mark the chart on the exact bar of a buy or sell? Maybe like an arrow at the buy and sell, or a line between them? Thanks! |
| [2016-01-19 18:02:22] |
Refer to the documentation here for this: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-19 18:21:24] |
Thanks, perfect!
| [2016-02-12 17:32:50] |
Hello support, Sorry to revive this old thread, but I have a related question. Is it possible to increase the width of the line that connects the entries/exits on the chart? I find it hard to see unless the chart is very large. Thanks! |
| [2016-02-12 19:20:42] |
Nevermind, found it. It's in Graphic Settings. Thanks! |
| [2016-02-12 20:40:20] |
This is set through Graphics Settings: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM This is the chart object you need to set: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Entry/Exit Connecting Lines Primary Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
