Date/Time: Tue, 08 Sep 2026 18:08:39 +0000
new user data feed
View Count: 899
| [2016-01-19 06:03:35] |
| User569214 - Posts: 4 |
i am a new user (trial ) i am using right now iq feed as my data provider , and it works fine , i would like to test your data 1 what data feed should i connect to in the global settings ? ? 2 also, does your monthly membership fee includes data feed ? 3 what exchange does it cover ? 4 can i get the bids and asks for the dax via your data feed ? |
| [2016-01-19 10:07:13] |
1. You need to follow through the Sierra Chart Exchange Data Feed Setup instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions 2. No, this is a separate cost. 3. They are listed here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges 4. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
