Date/Time: Sun, 05 Jul 2026 08:03:04 +0000
Alert to email a personalized note
View Count: 893
| [2016-01-19 00:20:03] |
| giggity - Posts: 2 |
i was wondering how i may have an alert email me a note that i have typed myself. for example, when price crosses 100 (=C>100) i would like for the email to display "Hello World". how do i do that? also, is it possible to have multiple alerts on the same chart? thank you.
| [2016-01-19 10:05:43] |
For each Alert Number it is possible to set a User Defined Name. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings So you can set "Hello World" as a User Defined Name on any of the 150 Alert Numbers. Once that is done, you can specify a specific Alert Number from a Symbol Alert. This User Defined Name will be in the email message. You can set up multiple Symbol Alerts: Alerts Manager: Symbol Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-19 10:06:07
| [2016-05-04 16:40:10] |
thank you very much for the information. i had a question. is it possible to put alerts on the server so that when the program isnt running the alerts are still triggered? i noticed today that the alert doesn't trigger when my computer is off. thank you in advance.
| [2016-05-04 16:43:54] |
No. This most definitely is not supported and never will be.
