Date/Time: Sun, 04 Oct 2026 09:41:42 +0000
Interactive Brokers After Hours Data?
View Count: 1636
| [2016-01-18 18:39:21] |
| User455772 - Posts: 22 |
Is there a way to fix the after hours data from Interactive brokers so that Sierra does not print a flat bar/candle with 0 volume on it after hours for every increment you have your timeframe setup at? It should only be printing a candle when there is actually volume traded on that candle...? Screen shot attached |
Attachment Deleted. |
| [2016-01-18 19:17:48] |
Looks like you enabled Chart >> Chart Settings >> Include Columns with No Data? You can also adjust the Session Times to filter the data out: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-18 19:18:14
| [2016-01-18 19:24:01] |
Hmm, I looked at that and I have it disabled. Any other ideas?
| [2016-01-18 19:32:15] |
I dont really want to do it by session time because I need to see incase there are trades later that I would miss
| [2016-01-18 19:36:20] |
I have noticed it only does this with Interactive Brokers data, and not the included Sierra data with the trial
| [2016-01-18 19:39:58] |
Therefore, probably you are using the Interactive Brokers True Real-time Data feature: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TrueRealTimeData Otherwise, we do not know why their system would behave in such a way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-18 19:43:01] |
That setting is set to False
| [2016-01-18 19:49:30] |
Here is a picture of the differences. I don't get why it would be loading this...
| [2016-01-18 19:51:27] |
Please ask Interactive Brokers about this.
