Date/Time: Sat, 28 Dec 2024 22:57:16 +0000
Referencing subgraph name
View Count: 1248
[2016-01-18 17:09:07] |
onnb - Posts: 662 |
See example - https://dl.dropboxusercontent.com/u/9913454/tmp/Screen%20Capture%20%23086.png Once user sets the reference in study settings, need to reference the subgraph name - is that possible? |
[2016-01-18 19:47:55] |
So you actually want to get the name of the Subgraph from another study? This capability is coming but it does not exist now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-18 20:03:21] |
onnb - Posts: 662 |
yes, that is correct do you have an ETA? |
[2016-01-19 01:03:03] |
Should be before June 2016. If it is something very critical, we could do a special function earlier, but that that function is eventually going to get replaced. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-19 18:48:05] |
onnb - Posts: 662 |
This is quite important. If you make a quick and a bit dirty solution for now, on our end we can later make changes as needed when you are ready with your long term solution.
[2016-01-21 05:39:17] |
We will see when we can get to this. However, please allow 30 days as we are extremely busy at this time.
[2016-01-21 17:46:03] |
We will do our best to get this done before the end of the week.
[2016-01-21 17:48:35] |
We assume this is for a study on the same chart?
[2016-01-21 18:21:57] |
onnb - Posts: 662 |
yes, we are referencing a spreadsheet study and its on the same chart.
[2016-01-21 19:25:07] |
In version 1357 there is this new ACSIL function: sc.GetStudySubgraphName(int StudyID, int SubgraphIndex); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
