Date/Time: Sat, 28 Dec 2024 19:50:01 +0000
number bar , blank space beetween price levels .
View Count: 1087
[2016-01-18 11:57:57]
User569214 - Posts: 4
i am using "number bars ",beetween every price level on the s@p futures i see a blnk box,which is a waste of screen space because every candle consumes more vertical space ..i am lossing screen space this way , is there a way to make the price levels to get closer to each other ? sincerely natan mortenfeld
[2016-01-18 12:11:14]
blank space between price levels , wasting vertical space , can you help ? image attached
http://www.sierrachart.com/image.php?l=1453118632580.png
[2016-01-18 18:45:21]
Select Chart >> Chart Settings.
Make sure the following settings are correct:
Tick Size: .25
Volume at Price Multiplier: 1
[2016-01-19 05:57:26]
thank you :-)
