Date/Time: Sun, 27 Sep 2026 12:47:41 +0000
Back Testing Primary Dataset
View Count: 1040
| [2016-01-18 09:50:10] |
| sigmadict - Posts: 95 |
Hello, When I start a Backtest and I have conditions on a moving average, the firts results are not accurate. Let's say I have moving average of 10 MA, I need 10 candles before my Condition become effective. So I would like to jump the Simulation (Replay Accurate System Back Test Mode) at the 10th candle. Is it possible to skip the first candles, so it does not affect my P/L$ ? Regards |
| [2016-01-18 09:51:07] |
Yes there should be a way to do this. Is this a spreadsheet automated trading system or one that uses ACSIL? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-18 18:07:50] |
Spreadsheet Automated System.
| [2016-01-18 18:08:34] |
The Internal Spreadsheets of Sierra.
| [2016-01-18 19:38:05] |
In the next release coming out in one or two more days there will be in I77 the following new field: Number of Bars You can then use this in a check in the Buy and Sell formulas to prevent a signal until there is a sufficient number of bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-27 04:29:54] |
Great Add-on, it feels good. Thanks. |
