Date/Time: Sat, 26 Sep 2026 01:06:10 +0000
Access to Platform
View Count: 949
| [2016-01-17 23:26:55] |
| sigmadict - Posts: 95 |
Hello, I am with a Broker and I use his configuration of the platform the "Broker Screen". I wanted to know if my broker was able to see inside the platform (indicators and spreadsheets), or it's only able to see me trades. I was always curious to know. Thanks |
| [2016-01-17 23:43:36] |
The broker will only be able to see non-simulated trading. This is all. From our position, we do not have access to anything in a Sierra Chart installation other than that you have logged in. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-18 03:53:40] |
When you say non-simulated trading, do you mean access to the platform, the indicators and the spreadsheets, or only to the trades ? Regards |
| [2016-01-18 05:07:39] |
We are referring only to trading order submissions, modifications, cancellations and positions. This is all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-18 05:07:57
