Date/Time: Sat, 28 Dec 2024 16:28:11 +0000
Question about the drawing mechanics
View Count: 669
[2016-01-17 08:05:18]
JRA - Posts: 97
For those traders that do not use time based charts, drawing a simple line, from the line tool, and extend it pass the fill space the, line shifts as new bars prints. I am simple asking if there is any chance you might consider changing the mechanics of your software so that a simple line drawn past the fill space will not shift. I have read in past threads that this is a limitation of the way non time based charts are build, but I have seen it work on other softwares.
[2016-01-17 21:19:59]
This is thoroughly explained here:
http://www.sierrachart.com/index.php?page=doc/helpdetails34.html
Refer mainly to the first three sections.
Please do not ask us anything further about this as we have no further response.
If you find that another program meets your requirements better in this way, then that is completely fine for us if you use that instead. The solution that we provide is the best there is.
Date Time Of Last Edit: 2016-01-18 00:40:08
