Date/Time: Sat, 11 Jan 2025 21:54:57 +0000
ACSIL: sc.TickSize from other chart
View Count: 2451
[2016-01-16 14:59:13] |
User53601 - Posts: 105 |
Hello, Is there a way to get an access to sc.TickSize in other Chart/Symbol ? |
[2016-01-16 17:35:00] |
This is not currently supported but will be sometime this year.
[2016-01-18 11:03:28] |
Marmany - Posts: 307 |
For info I achieve the result you are after by having a study on the transmitting chart with: float& TckSize = sc.GetPersistentFloat(123); TckSize = sc.TickSize(); Then on the receiver chart retrieve the value with a study containing: SCInputRef TckSizeFeed = sc.Input[1]: if(sc.SetDefaults) { TckSizeFeed .Name = "Tick Size Feed"; TckSizeFeed .SetChartStudyValues(1,1);// change digits as necessary } float TckSize = sc.GetStudyPersistentFloatFromChart(TckSizeFeed.GetChartNumber(), TckSizeFeed.GetStudyID(), 123); First time the receiver study is run make sure in Study Settings that correct Transmitter chart is being picked up. Hope this also works for you. |
[2016-01-18 12:45:23] |
Thanks, both Marmany and SC.
[2017-01-16 20:26:38] |
to SC: is this available already?: sc.TickSize in other Chart/Symbol |
[2017-01-16 20:36:27] |
No, this is not supported.
