Date/Time: Sat, 28 Dec 2024 16:18:18 +0000
New spreadsheets "insert column" shifts references so they are not correct
View Count: 703
[2016-01-16 09:50:07] |
pkhst958 - Posts: 57 |
Hi all, where can I set that "insert column" should not shift the references, so that they are still pointing to the right place? I know I could ensure that with adding the "$" everywhere, though I would like to have a general setting as I had in the old spreadsheets. |
[2016-01-17 21:40:10] |
We are going to be adding an option to control this.
