Date/Time: Sun, 13 Sep 2026 21:14:58 +0000
Help w/ maximum position quantities
View Count: 1223
| [2016-01-15 20:28:20] |
| User713273 - Posts: 409 |
Hi - I want to be able to trade multiple times up to the maximum quantity allowed. For instance if I set a limit of $10,000 and I get multiple orders those orders would cease to function when that limit of $10,000 is reached. Does sc.MaximumPositionAllowed functionality support monetary amounts? If not what ACSIL functions would work for this concept. Thx |
| [2016-01-15 20:35:28] |
The answer is no. You will have to do the calculations on your own to control this.
