Date/Time: Sun, 13 Sep 2026 22:54:44 +0000
Current Price Line distorts Numberbars bid/ask numbers
View Count: 1200
| [2016-01-15 17:38:22] |
| Mistic - Posts: 76 |
Noticing the current price line distorts the bid/ask numbers in numberbars. Can that be fixed? http://www.sierrachart.com/image.php?l=1452879469577.png |
| [2016-01-15 17:54:59] |
You need to move the Current Price Line study above the Numbers Bars study in the list of Studies to Graph. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-15 18:33:14
| [2016-01-15 18:15:28] |
It is below. The only way i can get it to be clear is to zoom in alot but i don't like being zoomed in that much. The numbers are clear when the line is not on them.
| [2016-01-15 18:33:44] |
We made a mistake. We meant you need to move the Current Price Line study above the Numbers Bars study in the list.
| [2016-01-15 19:26:44] |
Not sure that did anything. Just zooming in and out to get it just right when i see it fixes it. but thanks
| [2016-01-15 19:29:51] |
http://www.sierrachart.com/image.php?l=1452886129369.png I'd love to not have to be zoomed in more but this is what happens when its this far zoomed out |
| [2016-01-15 19:39:52] |
We have verified that line will be below Numbers Bars when the Current Price Line study is above Numbers Bars study in the list.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-15 19:41:20
| [2016-01-15 19:49:05] |
I never wanted the line to be below number bars. If you look at the last numberbar towards the right of the screen, 51-109. You see how the 9 in the 109 gets cut off when current price line goes through it. So far the only way I can figure out how to fix it, is zoom in more.
