Date/Time: Sat, 03 Oct 2026 19:24:04 +0000
Incorrect TRIN
View Count: 1520
| [2016-01-15 15:16:32] |
| conr - Posts: 204 |
Comparing your NYSE TRIN to others, it is way off. Currently yours is at 1.98 and the others are at 2.79. Others have high at 4.85 your high at 2.14. Why is this?
| [2016-01-15 20:30:53] |
The calculation of this can be found here: Sierra Chart Market Statistics: Symbols We had a look at the underlying market statistics this is calculated from and considering that the NYSE is down today, those values all look reasonable. Therefore, the calculation must be correct. We cannot comment on what you see with other services. You should look at the underlying market statistics and compare those with other services to get a better idea of why there would be a difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-15 20:31:55
| [2016-01-15 22:54:51] |
| conr - Posts: 204 |
I compared with three different services and went back several months. Your is consistently different from the three. This is the same situation as the TICK. Myself and numerous others brought that to your attention as well.
| [2016-01-15 23:00:34] |
There is definitely nothing wrong with the Sierra Chart NYSE TICK. We have discussed that at length here: Sierra Chart Market Statistics: Market Statistics Calculations Compared to Other Data Services Therefore, based upon that and based upon our analysis this morning we do not see any reason why there is a problem with the TRIN either. Any differences would have to do with the underlying market data but Sierra Chart is accurately tracking the stocks on the NYSE. So in conclusion, if you do not find what we have acceptable then do not use them. We are also certain based on extensive analysis up to this point in time that there are no problem with them. We have proven that. TRIN is calculated properly but has not been extensively analyzed like TICK but once again, we do not think there is any problem with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-15 23:01:52
| [2016-01-15 23:43:12] |
Also have a look at this thread: Article about Sierra Chart Market Statistics and their Accuracy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-16 22:51:08] |
And one thing we can say with certainty, is based upon our observation of the IQ Feed S&P 500 TICK is that most likely it is not completely accurate. Therefore, if that is not accurate, then logically the IQ Feed TICK for the NYSE is not completely accurate either. However, this cannot be proven, it is only based on circumstantial evidence. So therefore, extending this further, if market statistics from services other than IQ Feed are similar to IQ Feed, then perhaps those are not accurate either. So therefore, we will we will assert very clearly that the Sierra Chart market statistics are accurate as has been proven. We have looked at these time and time again and the more we look at them, the more we realize there is nothing wrong with them. It does not mean, that at times in the past there have not been times with small issues, or problems with the underlying data feed on certain days, but at the present time these issues do not exist. TRIN has not been extensively analyzed, but certainly TICK we are confident in its accuracy. But at this time, we have no reason to believe there is anything wrong with TRIN. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-17 00:50:50
